Brief Description: VA-146 Riveting and Fitment to Rear HS Spar
Assembled/Riveted VA-146 to HS-411. Used Rustoleum rattle can self etching primer and treated VA-146 after masking of bearing ends. Clecoed assembly back to rear spar and enlarged 4 holes to #12. Marked the parts and left assembled. Still required to accomplish cut out for rear spar to accommodate control horn movement. Marked and ready. Will accomplish this prior to final assembly.
Note: Ordered AZKO Primer and Alumaprep today. $$$$$ Expensive!!
