BRIAN'S WEB SITE
RV-7
Section 6
HS-411PP, HS-411BP & VA-146 bearing assembly
Clamped HS-411PP and HS-411BP with VA-146 sandwiched between. Attached entire assembly to Rear Horizontal Spar Assembly for match drilling. Match drilled 4 aft holes on bearing assembly as it was attached to the spar (as per plans)
RV-7 Home
101
76
