Install hydraulic brake master cylinder on the left control stick, there is not enough leg room if it is installed on the center mounted flap handle. Cut off MC handle to clear instrument switch panel.
Fabricate new C09-02 Flap Handle, with no bend, for center controls. Flap handle spring is Sonex P/N C06-15 "ST" Flap Spring. Install same.
Hydraulic Brake Master Cylinder Installed #4007
Hydraulic Brake Master Cylinder Installed #4008
New Flap Handle Installed - No Bend on Handle #4010
