Install springs & hardware for ACV-T01-01 Dial-A-Trim. Problem with the instructions, the reinforcement plate will not fit using the dimensions shown unless F03-01 Rear Spar Carry Through Assembly is modified by cutting a slot for the plate to fit.
Instructions say "Rear Spar Carry Through Assembly removed for clarity". Obviously it has not even been installed yet because in the picture there are no rivet holes in F24-05 Lower Cross Tie #1.
Mount AN42B-6A Eyebolt using a piece of 1/2" wide flat stock as reinforcement. Drill 5/16" hole in F25-01 Lower Cross Tie and install conduit retainer. Drill cable link 1 1/8" hole, 1 1/4" hole & deburr.
