Mark D02-02 Canopy for screws through D02-04 Forward Canopy Bow, D02-06 Aft Canopy Bow. Check spacing between canopy & bows. Step drill 5/64", 3/32" (will eventually updrill for 8-32 tap): D02-02 Canopy (need to updrill to 5/32") D02-04 Forward Canopy Bow (need to tap 6-32) D02-06 Aft Canopy Bow (need to tap 6-32) D02-07 L & R Side Tube (1st holes drilled from inside) D02-08 Canopy Corner D02-15 L&R Side Trim Cleco D02-07 & D02-08 from inside, then remove canopy. Drill #40 & cleco D02-06 Aft Canopy Bow, D02-10 Canopy Cross Tube, D02-09 x2 Gussett (1 left, 1 right)
Canopy & Right Side Hinge Drilled, Tapped & Fasteners Installed #3638
