Remote oil filter adapter and Moroso filter (Summit Racing P/N 22460) do not have the same mounting size. Adapter fitting is <1/2", filter has 1/2" thread.
Install parts from Sonex to make ACV-Q01-01 Throttle Quad (Left Side Mount) into Center Mount "ST" Throttle Quad. I had thought I could just use the left side Quad parts in the center, but the handle blocks the air speed indicator when in full throttle position.
Sonex tech support was very helpful in providing the parts required to make the swap.
Qty 1 ACV-Q01-31 Center Mount Throttle Quad Control Arm. Qty 1 ACV-Q01-34 S.S. Threaded Stud Qty 2 ACV-Q01-35 Conical Knob for Center Throttle Quad.
Install WagAero CM-24L Magnetic Compass on top of the glare shield.
Remove protective bar from under the instrument panel switches.
