Lube all parts then torque side 1 & 2 rocker arm shaft end bolts to 25ft/lbs. Install ACV-P01-16 Push Rod Tool, install rocker arm shaft assembly, torque mounting bolts to 168 in/lbs.
ACV-P01-16 Push Rod Tool is too long. Cut off 1/4", retap for 1/4"-28.
Measured lengths for each push rod:
#1 Exhaust 281 mm #1 Intake 281 mm #4 Exhaust 282 mm #4 Intake 282 mm #3 Exhaust 282 mm #3 Intake 282 mm #2 Exhaust 281 mm #2 Intake 281 mm
