Brief Description: Fuselage Cross Tie Box Assembly
Fabricate 1/8" x 1/2" flat stock x2, drill 7/64" & tap 6-32 to secure F24-13 Lower Web to bottom of F24-01 Cross Tie Box Assembly. This will make the lower web removable to check tightness of the F26-04L & F26-04R Upper Longeron Splice Plate bolts/nuts inside of the box assembly.
