TERRY'S WEB SITE
Date:  10-25-2015
Number of Hours:  5.00
Brief Description:  Fabricate & Install Main Gear Leg Fairings
Fitting L07-07 L&R Fairing Assembly to main land gear legs, connect brake lines.
Brake line and fitting info:
Brake line: NylaFlow Type H, A/S 05-04355 or Sonex provided tubing, no P/N.
90 degree caliper fitting x2 from Sonex, no P/N.
Tee at master cylinder: NAPA P/N 3700 1/8" Female NPT x3 ports
1/8" NPT Male x 3/16" compression fitting straight, A/S 268P-03 x2
1/*" NPT Male x 3/16" compression fitting straight, no P/N x1
Fabricate bracket to secure the tee fitting.
Bracket to Secure Hydraulic Brake Line Tee #4850
Bracket to Secure Hydraulic Brake Line Tee #4852
