Work on modifying the bottom oil cooler baffle seal, trim to fit, re-iinstall P13-02 Volkswagen Cowl. Document procedure for installing engine cowl:. Install: 1. Left half aft pin 2. Right half aft pin 3. Wire tie @ bottom center aft to hold halves tight together 4. Bottom center fwd pin 5. Bottom center aft pin 6. Bottom aft right pin 7. Bottom aft left pin 8. Left aft 3 SkyBolts 9. Right aft 3 SkyBolts 10. Top center pin 11. Front 2 SkyBolts
