TERRY'S WEB SITE
Sonex
Engine Cowl
9-12-2015
Engine Cowl
Install P-gasket on side engine cooling baffles.
Cowl no longer has the perfect fit to the fuselage. Remove the rear P-gasket, cowl is still too tight.
Remove P-gasket from the oil cooler baffle, cowl is still too tight.
Sonex Home
2005
Aircraft Kit
Aircraft Kit Details
Canopy #2
ELT
283
212
Engine Cowl
54
154
480
Hardware Kits
Hydraulic Brakes
Instrument Panel
Weight & Balance
Wheel Pants
538
Workshop
