Install tab to secure hinge pin on P13-21 Fuel Door.
Adjust depth of SkyBolt fasteners x9 on the rear of P16-03 AeroVee Engine Cowl and Fuel Filler Box, pull plastic pins to lock depth adjustments. Rivet the SkyBolt fastener to the Fuel Filler Box. (The 8 SkyBolt fasteners on the rear of the Cowl have been previously riveted).
Reinstall & cleco AeroVee engine cooling baffles. Punch holes for grommets ini the rear cooling baffle for various wires to enter the upper engine area.
Begin trimming / fitting the baffles and cowl on the left side.
