Secure hydraulic brake lines and master cylinder in forward fuselage area.
No one available to assist, so I used a jack to hold the phillips screwdriver under the fuselage while I tightened the nuts on the inside, then used a weight to hold the ratchet on the inside while I tightened screws on the outside.
Secure Hydraulic Brake Lines and Master Cylinder in Forward Fuselage Area #4926
Secure Hydraulic Brake Lines and Master Cylinder in Forward Fuselage Area #4927
Secure Hydraulic Brake Lines and Master Cylinder in Forward Fuselage Area #4928
