TERRY'S WEB SITE
Sonex
Fuel Flow Test
Fuel flow test.
Raise aircraft to 15 degree nose up attitude.
Minimum fuel flow shall be 80 HP X .55 X 1.5/60 = 1.1 lbs/min.
I ran 4 - 1 gallon fuel flow samples, which took 99 seconds, 100 seconds, 102 seconds, 105 seconds, for an average of 101.5 seconds.
128 oz / 101.5 seconds X 60/16 = 4.7 lbs/min, this easily surpasses the calculated minimum fuel flow of 1.1 lbs/min.
Aircraft at 15 Degrees Nose Up for Fuel Flow Test #5133
Aircraft at 15 Degrees Nose Up for Fuel Flow Test #5134
One of Several 1 Gallon Fuel Flow Samples #5137
Sonex Home
2005
Aircraft Kit
Aircraft Kit Details
Canopy #2
ELT
283
212
Engine Cowl
54
154
480
Hardware Kits
Hydraulic Brakes
Instrument Panel
Weight & Balance
Wheel Pants
538
Workshop
