Weigh aircraft with: Fuel tank empty With remote oil filter, oil temperature control & plumbing installed No iPad Mini, but its bracket is installed Flaps up at 0% Engine cowl installed Wheel pants and gear leg fairings installed Level aircraft at top of fuselage side skin, this required 25 1/4" under the tailwheel
Aircraft weights: Left Front 323 lbs Right Front 319 Rear 32 Total 674
