TERRY'S WEB SITE
Sonex
Aileron Rigging
Verify aileron rigging.
L&R bell crank angle = 25 degrees in relation to wing ribs.
Aileron delflection:
Left Right
Control stick neutral 0 deg 0 deg
Full Left 20 deg up 10 deg down
Full right 10 deg down 20 deg up
Tighten bolts on C03-03 Flap Push Rod, install cotter pins on same x2.
Secure outside ends of aileron hinge pins with cotter pins.
Reinstall wing tip lights.
Sonex Home
2005
Aircraft Kit
Aircraft Kit Details
Canopy #2
ELT
283
212
Engine Cowl
54
154
480
Hardware Kits
Hydraulic Brakes
Instrument Panel
Weight & Balance
Wheel Pants
538
Workshop
