Intending to bleed the hydraulic brakes today, but the wheel pants are not removable with the brake line connected. So I had to jack up the forward fuselage to remove the wheels. As long as I had the gear jacked up, I installed the MS20392-3C49 Clevis Pins & AN960-416 Washers, MS24665-134 Cotter Pins in place of the AN4 bolts per Sonex Rev 4.1.13 SNX-L07 NC Detail -08R/-08L.
This was done on only the bolts that goes throught the mounting tabs on both axles.
