TERRY'S WEB SITE
Sonex
Misc Fuselage Work
Tighten F26-04L & F26-04R Upper Longeron Splice Plate bolts inside of F24-01 Cross Tie Box Assembly.
Screw F23-13 Lower Web to F24-10 Forward Channel & F24-11 Aft Channel to complete F24-01 Cross Tie Box Assembly.
Install screws to fill holes in the instrument panel where the switch knee guard was removed.
Install missing screws x2 through F07-05 Instrument Panel Cross Tie & F07-06 Cross Tie Attach Plate & Upper Longeron.
Install vent hose on ACV-S03-01 Oil Separator using Watts clear vinyl tubing MSVLK10, Menards SKU 42143813.
Sonex Home
2005
Aircraft Kit
Aircraft Kit Details
Canopy #2
ELT
283
212
Engine Cowl
54
154
480
Hardware Kits
Hydraulic Brakes
Instrument Panel
Weight & Balance
Wheel Pants
538
Workshop
