TERRY'S WEB SITE
Sonex
Oops ! I have installed the oil separator ACV-S03-01 upside down. Reverse installation.
Drill holes for hydraulic brake lines in the forward fuselage.
Install a short piece of 5/16" steel brake line through these 2 holes to protect the NylaFlo brake line tubing.
NylaFlo = Aircraft Spruce P/N 05-04355 Type H, 3/16". This is the same type of tubing that was provided with the Sonex hydraulic brake upgrade kit.
Install plastic clamps in forward fuselage to secure the NylaFlo tubing.
Install NylaFlo tubing from both brake calipers to the master cylinder.
Sonex Home
2005
Aircraft Kit
Aircraft Kit Details
Canopy #2
ELT
283
212
Engine Cowl
54
154
480
Hardware Kits
Hydraulic Brakes
Instrument Panel
Weight & Balance
Wheel Pants
538
Workshop
