TERRY'S WEB SITE
Date:  9-29-2015
Number of Hours:  0.00
Brief Description:  Trim Length of AeroVee Exhaust Pipe
Trim the length of the AeroVee 2 into 1 exhaust pipes so the exhaust pipe extensions do not contact the engine mount.
Temporarily install the 2 into 1 pipes and extension pipes. Either the holes in the cylinder heads are not tapped deep enough or the bolts supplied with the engine kit are too long. Quality contol takes a holiday again. Need to retap the holes or use shorter bolts. Too late to retap the holes since the engine is already assembled and mounted, so shorter bolts it will be.
Install ACV-E01-23 x6 Exhaust Springs to exhaust pipe extenstions and to a s-hook clamped to the engine mount to support the exhaust pipe extensions.
