Mark L07-12R Right Wheel Pant for axle. Drill holes for back plate. Drill hole for brake fitting, cut slot for same. Drill hole in outboard side of pant for scew in center/end of axle. Assemble axle, back plate, caliper, wheel, bearings, washers, nut & cotter key. Install assembly onto gear leg. Lower Sonex fuselage, install wheel pant.
