TERRY'S WEB SITE
Date:  6-19-2015
Number of Hours:  5.00
Brief Description:  Engine Cowl Installation
Modify prop hub/cowl spacer, recess center area 5/32" per DWG, using fly cutter and sanding drum in drill press.
Install prop drive lugs into prop hub flange.
Drill 6 holes in prop hub spacer and mount spacer to prop hub flange.
Recessing Center Area of Prop Hub to Fit Prop Hub Flange #4014
Recessing Center Area of Prop Hub to Fit Prop Hub Flange #4015
Center Area of Prop Hub Recessed to Fit Prop Hub Flange #4017
