TERRY'S WEB SITE
Date:  5-17-2015
Number of Hours:  7.00
Brief Description:  Installing Oil Cooler Baffles
Work on installing cooling baffles for the oil cooler. A lot of trimming to make this fit.
Fit P30-40 Lower Case Baffle & P30-41 Upper Case Baffle to the crankcase.
Fit B&M 70265 oil cooler to the Lower Case Baffle.
Fabricate blank baffle for the back of the lower case baffle, this will force air through the oil cooler instead of allowing the air to pass straight through and out the back.
