Install Seat Belts. Bolt rear of L04-02 Tri Gear Main Mount with MS27039-4-24 x 2 (see DWG SNX-L04). Screw cover plates over unused Tri Gear axle holes in forward fuselage floor skin. Tighten bolts for:
F26-07L Left Hand Lower Vertical Splice Plate F26-07R Right Hand Lower Vertical Splice Plate F26-06L Left Hand Lower Horizontal Splice Plate F26-06R Right Hand Lower Horizontal Splice Plate F26-05L Left Hand Upper Vertical Splice Plate F26-05R Right Hand Upper Vertical Splice Plate F26-04L Left Hand Upper Horizontal Splice Plate F26-04R Right Hand Upper Horizontal Splice Plate
