Remove W22-01 L&R Wing Tip. Drill Nav-Strobe LED fiberglass mounts for AveoFlash LED's. AVE-WPSTR-61T A24-1404-01098 AVE-WPSTG-61T A24-1404-01098 Fabricate and install nut plate rings. Temporarily assemble all.
Saw a couple of Sonex aircraft at the Palmyra airport today, and after seeng their wing tip lights, I may relocate the LED's so they are at the top edge of the wing. If so then I will fabricate cover plates and use the already cut holes for wiring access.
Left & Right Wing Tips & Nut Plate Rings for LED's #3691
LED Mounted to Fairing & Wing Tip #3697
Nut Plate Ring for Fastening LED Fairing to Wing Tip #3701
