Fabricate & install L03-06 Tail Wheel Push Rod, using: Qty (1) 4130 .375 OD x .035 wall round tubing Qty (2) CW-4S Rod End Bearing with Threaded Stub Qty (2) AN490HT6P 1 Straight Stud End and 1 Threaded End Turn down straight ends of both AN490HT6P in drill press with a file to fit it into the 4130 tubing, assemble same. Drill stud & tubing 3/32", secure with qty (2) 3/32" roll pin for each stud. Bend tubing for correct geometry.
