Trim engine mount shims. Fabricate new shim for top left. Verify engine mount measurements: 22 11/16" from bottom front of fuselage to front of motor mount pins Motor mount pins square with jig angles bolted to bottom of fuselage 12 3/32" from top of fuselage jig angles to center of bottom motor mount pins
Drill #30 & cleco: P31-01 Engine Mount F15-01 L&R Upper Motor Mount Angles F15-02 L&R Lower Motor Mount Angles Shims
