TERRY'S WEB SITE
Sonex
Rudder Control Cables
Center rudder & clamp in place, measured from center of rudder to straight edge on both sides of the vertical stabilizer, both measurements are equal at 1 5/16".
Install C02-03 L&R Cable Adjusters to C02-09 Rudder Pedal Assembly, drill & bolt.
Left Rudder Cable Adjuster & Spring Installed #3093
Right Rudder Cable Adjuster & Spring Installed #3094
Sonex Home
2005
Aircraft Kit
Aircraft Kit Details
Canopy #2
ELT
283
212
Engine Cowl
54
154
480
Hardware Kits
Hydraulic Brakes
Instrument Panel
Weight & Balance
Wheel Pants
538
Workshop
