Brief Description: Fabricating New Elevator Assembly
Fabricating new T02-03 Elevator Assembly. Cleco hinge on T02-03 Elevator Assembly to T02-02 Horizontal Stabilizer Assemby. Drill #40, #30 T07-04 L&R Elevator Root Rib. At this point it is very evident the original alignment problem with the elevator and H-stab alignment is the dimensions of the factory fabricated part T06-01 Elevator Control Horn Welded Assembly, it is far from being symetrical. If I had followed the instructions the first time everything would have been ok, but now after fabricating a new elevator assembly all is good.
New Elevator Assembly Completed, Root Ribs Clecoed #2997
