Install & cleco F06-01 Glare Shield. Install & bolt G01-10 x 4 Fwd & Aft Fuel Tank Straps to F13-02 L&R Upper Longeron & F06-01 Glare Shield. Remove F07-05 Instrument Panel Cross Tie to slide in G02-01 Fuel Tank. DWG SNX-G01 calls for AN3-10A bolt x 2 to bolt together G01-08 x 2 & -09 x 2 Forward & Aft Straps, but my kit came with G01-10 x 4 straps. Instead of AN3-10A, need to use AN3-22A bolts.
