TERRY'S WEB SITE
Sonex
Rear Spar Carry Through & Tri-Gear Mounts
Drill #40:
F03-08 Shear Angle
F24-05 Lower Cross Tie #1
Remove F03-01 Rear Spar Carry Through Assembly
Drill #40 & #30 F03-03 x 2 Fitting, F03-06 L&R Attach Angle, F03-07 x 2 Spacer
Dis-assemble & deburr:
F03-02 Channel
F03-03 x 2 Fitting
F03-04 x 2 Spacer
F03-05 L&R Angle Fitting
F03-07 x 2 Spacer
F03-08 Shear Angle
F12-01 L&R Forward Side Panel Assembly
Re-assemble, cleco, rivet & bolt same
Forward Side of Wing Spar Tunnel #2958
Left Tri-Gear Mount Fitting #2963
Right Tri-Gear Mount Fitting #2964
Sonex Home
2005
Aircraft Kit
Aircraft Kit Details
Canopy #2
ELT
283
212
Engine Cowl
54
154
480
Hardware Kits
Hydraulic Brakes
Instrument Panel
Weight & Balance
Wheel Pants
538
Workshop
