TERRY'S WEB SITE
Sonex
Wing Attachment & Firewall
Step drill to 3/8":
F14-08R Forward Wing Attach Angle
W11-05L End Attach Angle
W11-03 Wing Attach Block
W11-04 Shim Plate
W11-07R Root Attach Angle
F14-08L Forward Wing Attach Angle
W11-05R End Attach Angle
W11-04 Shim Plate
W11-07L Root Attach Angle
Install & cleco F16-03 Aft Tunnel Web Assembly
F14-09 L&R Aft Wing Attach Angle
Remove, debur, re-assemble & cleco:
F14-01 L&R Forward Angle Assembly
F15-01 L&R Upper Motor Mount Angle
F14-05 L&R Upper Firewall Attach Angle
F14-06 L&R Lower Firewall Attach Angle
F17-01 Lower Firewall
F16-09 Upper Forward Cross Tie
F17-08 Firewall Stiffener
F17-11 Gussett
F17-10 Upper Clip
Bolt:
F15-02 L&R Lower Motor Mount
Sonex Home
2005
Aircraft Kit
Aircraft Kit Details
Canopy #2
ELT
283
212
Engine Cowl
54
154
480
Hardware Kits
Hydraulic Brakes
Instrument Panel
Weight & Balance
Wheel Pants
538
Workshop
