DWG SNX-F07 has engineering revision note C, 11/13/03, "Removed -07R Left Hand Corner Plate & replaced with -11L Left Hand Corner Plate. Removed hole for throttle & added material to inboard side to provide additional space for throttle location." I have a part marked -07 & no -11. I also have no .090 to fabricate one. Sonex engineering revisions from internet make no mention of this. I have version Aug 24, 2011. DWG SNX-07 is wrong, -07L is now -11, not -07R.
Bend flanges on F07-03 Instrument Panel. Cleco F07-06 x 2 Cross Tie Attach Plate to F07-05 Instrument Panel Cross Tie. Cleco F07-11 Corner Plate & F07-07R Corner Plate to F07-03 Instrument Panel & F07-05 Instrument Panel Cross Tie to make F07-02 Instrument Panel Assembly. Drill #40: F13-03 L & R Upper Longeron F14-08 L & R Forward Wing Attach Angle Cleco F07-02 to same, spacing .030 @ F13-02 L & R Upper Longeron for F07-02 Glare Shield. Cleco F17-02 Upper Firewall Assembly to F17-01 Firewall.
