Fit F15-15 x 2 Flap Drive Pivot Block to C04-05 Flap Handle Assembly. Rivet: F14-10 x 2 Gusset F14-12 L & R Seat Belt Attach Angle F15-12 L & R Angle Clip F15-11 x 2 Seat Belt Attach Gussett to: F14-13 L & R Horizontal Angle F13-06 L & R Lower Longeron F13-01 x 2 Forward Fuselage Skin
Bolt: F15-12 L & R Angle Clip Rear Spar Carry Through Assembly F03-01 Fabricate F03-04 x 2 Spacer Fabricate F03-07 x 2 Spacer Drill #40, cleco, assemble F03-02 Channel, F03-03 x 2 Fitting, F03-04 x 2 Spacer, F03-05 x 2 Angle Fitting, to make F03-01 Rear Spar Carry Through Assembly. Drill same #30 & cleco.
Step drill: F03-02 Channel F03-03 x 2 Fitting F03-04 x 2 Spacer F03-05 x 2 Angle Fitting to 3/16" & bolt x 3.
Cleco F03-08 Shear Angle to F03-01 Rear Sparr Carry Through Assembly. Drill same #30 & cleco.
Rivet: F15-07 L & R Flap Drive Mount F15-08 x 2 Spacer Plate to: F13-06 L & R Lower Longeron F13-01 x 2 Forward Fuselage Side Skin F14-08 L & R Forward Attach Angle
Rivet: F15-06 x 2 Doubler F14-10 x 2 Gussett F15-14 x 2 Doubler Support Plate F14-08 L & R Forward Attach Angle F13-01 x 2 Forward Fuselage Skin
Rivet: F14-08 L & R Forward Wing Attach Angle F14-10 x Gussett F13-02 L & R Upper Longeron Assembly F13-01 x 2 Forward Fuselage Skin
Misc Parts Riveted to Right Forward Fuselage #2700
