Brief Description: Misc. Left Wing Work & Debur Wing Parts
Drill #40 and cleco W21-09 x 2 Clip to W19-02L Left Lower Aft Wing Skin (part of W21-02L Left Hand Aileron Bell Crank Assembly). Attach W18-02 Cover Plate to W19-02L Left Lower Aft Wing Skin and nut plate ring (temporary to get nut plate ring inside of skin before riveting). Drill 3/8" hole in W19-02L for AN46-7A Left Tie Down Bolt, still need to punch the hole out to 7/8". Debur top side of W12-01L Left Rear Spar. Debur top side of W16-01 thru -04, -05 x 8 Aft Rib and Root Rib. Debur top side of W08-01L Left Main Spar. Debur underneath top & bottom side of W08-01L Left Main Spar. Debur underneath top & bottom sides of W12-01L Left Rear Spar. Debur W06-06L Left Fland Hinge Half (Wing Half).
