Brief Description: Left Landing Light, Left Wing Skins
Continued installing left landing light. Completed execpt for installing the lamp and lens. Drill #30 and cleco W20-01L Left Hand Root Doubler / Wing Walk and Root Doubler on lower side. Drill #30 and cleco W18-01L Upper Left Forward Wing Skin and W19-01L Left Aft Upper Wing Skin to W08-01L Left Main Spar. Drill #30 and cleco W19-02L Left Aft Lower Wing Skin to W16-01 thru -04, -05 x 8 Aft Rib & Root Rib. Drill #30 and cleco W18-01L Lower Left Forward Wing Skin and W19-02L Left Aft Lower Wing Skin to W-8-01L Left Main Spar and Root Rib. Fabricate nut plate ring for W18-02 Cover Plate. Nut plates = Wag Aero L-699-700, 31-E03; screws = Wicks AN526C-6R8, aluminum pan head.
Left Wing Access Hole Cover Plate and Nut Plate #2522
