Brief Description: Wing Tie Down Fitting, Left Aileron Linkage
Bolt W11-10L Left Hand Tie Down Fitting, W11-11 Outboard Vertical Stiffener Angle to W08-01L Left Main Spar. Begin assembling left aileron linkage. Drill 3/32" witness hole in 3 MW-5 Rod End for left aileron linkage. Drill 3/16" & 5/16" holes in W21-11 Aileron Bell Crank Plate. Assemble C3-08 Short Aileron Push Rod & MW-5 Rod End. Assemble C5-05 Long Aileron Push Rod Dual Stick. Assemble W21-11 Aileron Bell Crank Plate to W21-02 Aileron Bell Crank Assembly.
