Brief Description: Install Right Wing Forward Wing Skin
Setup ratchet straps to secure W18-01R Right Hand Forward Wing Skin. Eye bolts through work bench on lower wing side, C-clamps on upper wing side, 2 x 4 under straps across wing skin. Ratchet down until trailing edge holes line up. Drill #40 and cleco lower trailing edge to leading edge of W19-02R Right Lower Aft Wing Skin. Drill #40 and cleco remaining holes in W18-01R Right Hand Forward Wing Skin, except for W20-01R Root Doubler. Drill #30 and cleco lower trailing edge of W18-01R Right Hand Forward Wing Skin. Did not updrill rib holes, these get flush rivets.
