Drill out W11-01R Tie Down Fitting to 3/8" and install same to W08-01R Main Spar. This bolt is kind of too long, had to install 4 washers under the nut. Install cotter pins for C3-02 Aileron Push Rod and C5-05 Main Aileron Push Rod Assembly MW-5 Rod Ends. Tag the rod ends - still need to adjust and tighten the jam nuts.
Aileron Push Rod Assembly Installed on Right Wing #2226
