TERRY'S WEB SITE
Date: 5-6-2012
Number of Hours: 3.00
Brief Description: Landing and Nav Light Wiring
Install grommets for landing and nav light wiring tubing, Menard's Gardner Bender p/n GHG-1575 SKU .32076 89831, 3/4" 19.1 mm, drilled 7/8" hole with unibit. Install snap bushings for Pitot and Static tubing, DWG W23 calls for 1/2" O.D. x 3/8" I.D., but none found in Wicks hardware kit, used Reineman's True Value p/n 58159. Bolt on W11-06 Root Wing Attach Assembly, AN3-7A x 3, MS24694-S56 x 3 (DWG calls for S58, too long). Bolt on W11-02 End Wing Attach Assembly, MS24694-S56 x 2, MS24694 -S54 x 1 (DWG calls for -S56, too long). Rivet trailing edge of W19-01 Upper After Wing Skin where wood support blocks were.
