Adjust thickness of symco thrust bearing, assemble C3-08 Short Aileron Pushrod to W21-10 Aileron Bell Crank Assembly. Assemble MW-5 Rod End for C5-05 Long Aileron Push Rod, Dual Stick. Debur all W14-03 Web Spacer and W14-02 Center Spacer for W16-01 thru W16-12 Aft Rib. Cleco W14-03, W14-02 and W16-01 thru W16-12 Aft Rib to W8-01R Main Spar. Uncleco W16-01 thru W16-12 Aft Rib from W12-01 Rear Spar Assy. Uncleco W13-01 Right Hand Attach Plate, W13-04 Doubler and W13-05R Right Hand Attach Angle from W12-01 Rear Spar Assembly. Debur all, reassemble and cleco.
