Finish work on: W11-05 x 2 End Attach Angle. W11-07 x 2 Root Attach Angle. W20-02 x 2 Root Rib Attach Angle (Aft Rib forward end). W20-03 x 2 Root Rib Attach Angle (Fwd Rib, aft end). W11-11 x 2 Outboard Vertical Stiffener. W13-02L Left Hand Root Rib. W11-10L Left Tie Down Fitting. W10-10R Right Tie Down Fitting. Drill #40 and cleco W11-05 End Attach Angle and W11-04 Shim Plate, W11-03 Wing Attach Block to make W11-02 End Wing Assembly. Drill #40 and cleco W11-07 Root Attach Angle, W11-03 Wing Attach Block to make W11-06 Root Wing Assembly. Drill #30 and rivet W17-01R Root Rib Assembly and W17-04, -05 Re-enforcement Angle, W20-02 Root Rib Attach Angle (W10-2 and -03 not riveted at this time, need these off to drill holes in ribs and main spar) to W16-01R Aft Wing Rib and W13-02R Root Rib Attach Angle at aft end of W16-06. Drill #30 and cleco W17-01R Root Rib forward and aft to W08-01R Right Main Spar.
