Brief Description: Assemble Main Spar, Ribs and Rear Spar
Assemble and cleco W08-01R Main Spar, W15-05 x 12 Forward Rib, W16-06 x 12 Aft Rib and W12-01R Rear Spar. I purchased the prefabricated Main Spar, and it has a nasty warp to it at the wing tip end. I clamped the Rear Spar to the work bench to maintain all parts level and square from one end to the other for assembly. Fabricate W10-06 Tip Attach Angle. Drill #40 and cleo to W08-01R Main Spar.
Rear Main Spar is Clamped to Work Bench to Maintain Wing Parts Level and Square #2183
#2184
Right Wing, Main & Rear Spars, Forward and Aft Ribs Assembled #2186
