Brief Description: Fabricate Brackets for Static Tubing
Fabricate W23-08 x 4 Tubing Support Plate for static tubing. Cannot find plastic snap bushings, 3/8" x 1/2" p/n 2030 in Wicks hardware kit. Trim W16-03, -04, -05 Aft Rib Assembly to clear spar cap. Drill #40 and cleco W23-08 x 4 Tubing Support Plate to W15-01, -02, -03, -04 Aft Rib Assembly. Trim ends of W15-06 Aft Rib for Root Rib Assembly. Make template for trimming forward end to clear spar cap.
