Finish work on W13-03 x 4 Radius Block. Oops! I have drilled the holes for W13-02L Root Rib Attach Angle incorrectly. In an effort to make sure both wings were created equal, and build them at the same time, I failed to notice that W13-02L & R are not installed in the same direction. After flipping Attach Angle around the holes are only off by ~1/8", but there is no way to fix this mistake. I have ordered a 96" length of Z01-02 to fabricate a new W12-02L Rear Spar Channel.
I was not going to have enough workspace to build both wings at the same time anyway, so I will build right wing first.
