Brief Description: Assemble Vertical Stabilizer Parts
Worked on bending T12-07 Forward Spar Fitting 35 degrees. I took extra time on this to avoid marking up the piece while bending it like I did on the rudded drive horn.
Assembling T12-01 Main Spar Assembly; drill #40 and cleco T12-02 Main Spar, T12-01 Main Spar Aft Strap, T12-03 Upper Spar Channel, T12-04 Lower Spar Channel, T12-05 Angle, T12-06 Clip, T12-07 Forward Spar Fitting.
