This was actually the second leak check of the tank, since the first leak check resulted in leakage around the access cover. As per my previous entry, I used the fuel resistant lube and It worked great. No leaks except around the drain pipe thread fitting. I can fix that later. Woo hoo!
We also installed the last z bracket that I was having trouble with. I decided to just drive an AN470 rivet instead of a cherry rivet. I was too cheap to buy the correct rivet puller for the cherry rivets I bought. The solid rivet worked great when i used the trimmed offset rivet I used on the wing LE ribs.
Boy, these pictures are ugly. I really need to get another camera.
