RUSS'S WEB SITE
Date:  1-24-2009
Number of Hours:  6.00
Manual Reference:  Plans and photos
Brief Description:  Wired cable to servo and worked on trim tab
Carefully studied the documentation of the servo unit. Did a breadboard wiring hookup of the push button control, the display and the servo using a 9V battery source. It all worked fine. Reset servo to mid position. Wired the leads from the servo to the 5 foot 5 conductor cable. I twisted each bared wire together then soldered. Trimmed off any sharp potrusions. Covered with liquid tape then slipped a shrink wrap over each wire. Then made two bundles (1) the black and white power wires and (2) the 3 other control wires. After that I enclosed each bundle in a larger shrink tube and heated it securely tight using a hair dryer. After that I enclosed it all in a spiral wrap. See picture.
Measured and drilled the holes for the mounting of the servo in the upper skin. Also safety wired the trim tab hinge pin.
Preparing to install the servo
The servo ready for installation
How the servo moves the tab
