RUSS'S WEB SITE
Date:  8-24-2010
Number of Hours:  33.10
Manual Reference:  video
Brief Description:  Jury Struts
These hours accumulated as follows:
Date RR CJ
8/19 1.3
8/20 4.0 4.0
8/21 5.9 2.7
8/22 8.3 8.3
_____________________
19.5 13.6
All the flaps were attached permanently. The RH slats were attached and affixed permanently. The right hand jury struts were fitted, trimmed and attached permanently. The left hand jury struts are held by three clamps and then they will be finished.
The jury struts took much more time than anticipated. The brackets are so close to the lower surface of the wing that they can be drilled only from one side. The steel tubing is small so the tolerances to go straight through to the pilot hole on the bracked on the other side is tedious. We worked it ok on the RHS. The LHS is next. Attaching, holding and fitting the AN3 bolts into the lower brackets is also tedious.
Photos next time.
