Reworked the canopy track assemblybecause of interference issues with the rear slide block. Purchased wider rail and larger base and slide block from Van's Aircraft. The new track was fitted, drilled and clecoed in place. Also fabricated mount for GPS antennas and integrated into the track rail mount in the hat rack area. A new guide block will be fabriocated to match up with the canopy bracket.
